murraymcleod wrote:
dougrainer wrote:
The Hot water runs thru the Water Heater loop all the time. You do NOT have to turn the Water Heater ON. You CANNOT even turn this heat function OFF to the Water Heater. Doug
That probably explains why my RV runs pretty cool most of the time(not much over 150 degrees according to the gauge)!
(BTW....anyone know why the "subscribe and send email notifications..." doesn't seem to work for me?! The signature only seems to work intermittently as well, or does it only show once per thread?)
If your engine is NOT running to temp spec, it will NOT be the rear heater and Water Heater Motoraid system causing that. Doug
