fortytwo wrote:
One degree means that the temp swing is TWO degrees. Set at 80 the A/C shuts off at 81, then stays off until temp drops to 79 before turning back on. My wife has severe neuropathy. She has a one degree tolerance before adjusting layers she wears. It's not difficult to distinctly feel the extremes in our 30T.
If the accuracy is 3 to 5 degrees we could be experiencing 6 to 10 degree swings. Recognizable by anyone.
I am sorry your wife has a health issue. But, the system is performing better than it is designed too. I do not think you can find a better system or fix for your problem. The 3 to 5 is the specs. But NOT hard specs. If you would complain about a swing that is what both Dometic and RVP would tell you. I think you reversed your problem on this post. Doug
