spotrot
Jun 11, 2015Explorer
More facts and theories on the Vetrolite failures:
CDI, applies only the full body paint for Winnebago. CDI uses Sikkens & Sherwin Williams products.
Winnebago does the partial paints, CDI believes Winnie uses DuPont (now called Axalta), single stage with a clearcoat. (A Winnie CS rep told me they use Imron 5000 with clearcoat for their partial paint schemes.)
CDI has refinished vetrolite. (Other brands of siding have failed too)
CDI applies 3 heavy coats of 2k primer, sands this, then sometimes applies a sealer before the basecoat (color), then 3 coats of clearcoat before sand & buff. Cost for this type of refinish for entire RV is $14-18k.
"The finish may later crack. (The cracks in Vetrolite are likely to enlarge.)"
CDI was very helpful and knowledgeable. From other posts, forum members have been pleased with their refinish quality and speed,
After 7 years outside mostly in Florida sun, the partial painted areas are excellent. The white of the front cap is good too, just the normal dulling expected with a gelcoat. Strangely the rear rear surface is excellent too (Maybe not Vetrolite?)
The Vetrolite sides where not painted look terrible as posted above. The area below the Sunova decal we removed shortly after purchase is still excellent. Theory: the decal may have allowed the surface of the Vetrolite to fully cure before exposed to UV or ozone. If so, the Vetrolite on RV's that saw little sun, or were garaged for the first year (or were made from older or better panels) might not fail for a long time.
Any experience good or bad refinishing failed Vetrolite sides would be appreciated.
My thought for now is to use the brush/roller technique to repaint the sides with a 2k single stage urethane.
