I just ordered the Jack and will report back once I get it installed. It would seem to me that the ability to rotate the antenna along with having the signal monitor will be a help in receiving the maximum number of stations at your location. The strength of the signal I get at home on a television we don't have hooked up to cable is very much depended on the direction the UHF antenna is facing. If you turn it 10° ~ 15°C from what I found to be the optimal direction and the signal strength drops off significantly.
