I own a 40' DP. I’ve noticed that some RV owners use jack pads on level, hard packed surfaces, while others do not. What are the benefits of using jacks pads on such surfaces when raising the RV is no...
We use Harvest Hosts from time to time and as a courtesy put down jack pads, even though the ones on mine are ~ 9" diameter. I have an old rubber truck bed mat cut and put those under the plastic lego's. Also with this recent extreme heat, I've used in CG's that have macadam pads to help prevent sinking into the surface. Otherwise on hard pack I don't use anything.
