JRscooby
Nov 16, 2020Explorer II
Likely to late now, but pull the flat up on a ramp/block to get the hub as high as normal, then jack it up. When you are ready to put tire back on you know you will not have to get under to raise it a little bit more. That bit is when most likely to slip, and with no wheel in place, most chance of damage.
38,782 PostsLatest Activity: Sep 10, 2026
