Executive45
Nov 17, 2020Explorer III
Keep in mind the rear tires are the easiest to change. You don't even need a jack if it's an outside dual. Simply drive onto a chock block with the inner wheel and remove the outer one. Put the new one on and drive away.
Be sure to recheck the torque on the lug nuts after a couple hundred miles....Dennis
38,782 PostsLatest Activity: Sep 10, 2026
