dshinnick's avatar
dshinnick
Jacks getting sluggish
We have a 2005 Holiday Rambler Ambassador, 40' DP. Overall in very good condition, except that the jacks have recently begun to be quite sluggish on retracting.
Going down is no problem. But coming up, especially the rears, I hold my breath each time. Sometimes they'll come up a few inches and stop. We reverse them for a second, then try again. Sometimes they'll then come up, sometimes not. Sometimes they just won't move at all at first, and we have to extend/retract/extend until they finally decide to retract.
I looked in the manual and there is a fluid reservoir, but the manual says that the fluid only affects the extension, not the retraction. Perhaps that's not so. I thought maybe the springs which help pull the jacks up might be getting weak, but that wouldn't explain why they're very sluggish at first, but then eventually retract ok.
So, any thoughts?
thanks-
dave
  • Do you have zerk fittings at the bottom of the jacks, they may need a small shot of grease.
  • Sounds like your return valve is not opening all the way. Check the electrical connections at the valves.
