mercedesme28's avatar
mercedesme28
Jacks on a 1992 Bounder
I have hydraulic jacks to level my rig, they are on the floor next to the driver seat and I control each one With a lever
They have worked fine however today I turned the switch on and the lights come on but I get no movement, the jacks don't move,no noise,nothing
I checked the fuse and it's fine
Where do I look next ?
Thanks
  • Gjac's avatar
    Gjac
    Explorer III
    Are the HWH jacks 200 series? If so I would look in the engine compartment it should be a black box right in front of the radiator. But I doubt that low fluid is causing this problem. If you go to their website they have a good troubleshooting guide there. That will get you started and you could post back what you find after going through the troubleshooting steps.
  • I checked the fuse next to the levers
    Where were the other fuse be or hydraulic fluid container
    I was once told by somebody that it might be transmission fluid and not hydraulic fluid is that possible
  • There is a fuse up by the hydraulic motor, did you check that one?
  • I have a 1989 Bounder with the same levelers. Check your fluid level in your reservoir. Also, check your fuse where your leveler handles are.
