dleslie125
Apr 23, 2014Explorer
j-d wrote:
What CAN it do and what SHOULD it do are not the same questions. Max everything out and you'll feel it. Load the RV and select a toad that reduces GCWR to say a ton or so below max and you'll like it. We towed an older mini-pickup that weighed about 2500. Replaced with one that weighs about 4000. Still within our 5000 towing but we can feel the difference. We only have been going locally on flat ground so it's OK. If we planned on long trips I'd want to set up our Corolla that weighs about the same 2500 as the old truck did.
Where will you be going? Short trips flat ground, maybe OK to max out. Long trips and steep grades, better think twice.
I think a point that is critical is "what will the toad be used for when not being towed."
If it is just a toad then I'd be prepared to go small like an older Tracker. BUT, if it is a vehicle I have to use daily NOT A HOPE. DW has the same view.
We dumped our Escape because all we did was worry if the transmission was going to go (but we did EVERYTHING by the book - it didn't but SanGauge showed transmission fluid temp of 220 deg when towing (engine off and no torque going through)). It was a nice weight for the Navion - but just a PITA because of the worry. DW loved it and the ONLY reason it went was to get something with a transfer case with NEUTRAL. Our Colorado towed fine, as did our Tahoe. Escape towed fine but the worry was just not worth it. We were going to put in a lube pump but Ford really screwed us on that one. They took over the REMCO pump for the Escape and Fusion and wanted over $5,000 installed. NOT A HOPE.
Ford does have some smaller cars that are towable and would be fine BUT we have to have at least one large vehicle (and the T&C has been perfect for that role) and DW will not drive a large vehicle anymore nor anything where you sit down low. End result is choice is limited - especially since my desire was to have a transfer case with N. We were within 2 minutes of signing a deal for an Edge AWD Limited (no transfer case) and then concluded that Ford didn't deserve the biz from us.
To the OP, good luck in your search.
