sealevel ram wrote:
Is it OK to start a MH (or any other vehicle) with a battery charger attached?
In other words, use the charger as a jumper?
I have one of those portable jump starter things, but it doesn't appear to be working great.
Thanks.
Well,
Yes and no. The very first things to consider here are the coaches battery connections. While some connections LOOK good, they in fact are not. Removal of them will reveal corrosion and poor contact. And, many RV DIY types, focus on the POSITIVE cable connections without paying any attention to the NEGATIVE ends. I've seen many, many negative ends attached to the frame, with tons of rust, corrosion, road debris etc. all around those connections.
And, once the corrosion starts at an end, it can easily migrate up the cable. So, with all that being said, make sure your connections (at both ends) are in great shape and, also, make sure you're not dealing with a battery or, batteries, that have potentially dead cells. If you have a dead cell, all the jumpers in the world ain't gonna help your situation.
If your batteries are in great shape and, your cables too but, you simply left an accessory on which drained them to the point of not enough cranking amps left, yes, those little Jumper packs should do the job. Mine has a 600 amp rating. I tested it on our dead truck one time and, it started that truck better than the original battery did.
Scott
