RandandDoug's avatar
RandandDoug
Keyless entry touchpads
I thought I had seen a couple topics on new uprgraded keypads for a keyless entry on Newmar Mountain Aire. Cannot seem to find it now, any help.
I think the name of the company was listed, I am forgetting it all now.:S
Thanks,
Doug
  • Newmar has changed the type keypad. If you have an older Newmar and the touchpad is mounted in the sidewall, the new Keypad is larger and better sealed. You have to cut the hole out a little larger. Newmar carries the replacement. I believe it is still called the Essex brand, not to be confused with the Newmar Essex motorhome. The older Keypads went out after 2 to 4 years and the new one will probably last a lot longer. Doug
