Gundog wrote:
Yes the kitchen is in one of the slides I will have to check for a kink but I can see the antifreeze in the lines up to the faucet (it has been winterized). I have removed the faucet from the MH took it apart and blew it out with compressed air disassembled it blew all the parts out with air nothing changed when I re-assembled it. I can't blow air through it when it is assembled but I can blow air through each part when it is not assembled. There is a little plunger valve for the sprayer I took it out also and blew it out. It just doesn't make sense to me.
I plan to replace it with another faucet I think the problem is in the valve that allows the sprayer to work and yes it is separate and not one that pulls out from the end of the spout. I have not tried it on city water because I winterized it already I removed the faucet thinking I could just clear a clog.
Does the pull out spray spray well but the main faucet not? If so, it's the valve or the aerator but it sounds like you removed the aerator already. If it's an issue with both and you don't have any kinked lines I would suspect you need a new fixture.
