jolooote wrote:
Hi. I had the same problem & did the 'Hit it with a rubber mallet' trick for 3 years. I finally replaced the motor. Look for a left front window motor for a 1986-1995 Ford Taurus. Also, look at the NAPA part # BK655-1395 or Dorman # 742-205 0r 206. You may also want to read the old posts from a guy called OZARKWOODS.
I tried Autozone with P/N 742-277 that someone posted as 1986 Ford Taurus driver side unit. It did not match mine. The gear shaft was round without the flat side that mine has and smaller dia. shaft. Did you have to modify anything or was it a bolt-on. Thanks Gary
