I have a 2004 Allegro with KwiKee steps that will not retract with the step sw. , the door closing or the ignition bypass, has anyone else had this problem ?
If you go to the manual it gives you some simple steps to check the switch,motor and controller. If you apply 12 v to the motor and it works its not the motor. Is the controller potted? or is it a board with individual components soldered to it?
