twobags's avatar
twobags
KwiKee Electric Steps
I have a 2004 Allegro with KwiKee steps that will not retract with the step sw. , the door closing or the ignition bypass, has anyone else had this problem ?
  • I had the same problem it was the magnet switch in the door frame. Not saying that is your problem but it could be. If you order new ones stay with the color.
    so long of the short the steps are stuck open?sounds like the controller went out
    take the two motor drive wires and put 12V to one and ground the other and then reverse to see if u can get them in and out if so its most likely the controller
