MrWizard wrote:
No adjustments
The parts are all fixed length
Gears wear, and the ball joints at the end of bells crank wear
If it stays up, and doesn't come down you are ok
Pretty much the correct answer here. The ONLY adjustments on any Kwikee steps I've ever seen and owned are the cams on each side. And contrary to some believers, those cams have absolutely NOTHING to do with STABLIZING the steps. All they do is allow for a coordinated stop that ties in with the end of the motor/swing arm travel so the steps stop with the cams and the end of the travel, at the same time.
Other than those, as stated above, the travel is a fixed distance, in both directions with no possible adjustment.
Scott
