AikenRacer's avatar
AikenRacer
Kwikee step issue
My class A steps (2) were staying open. The door magnet is ok. I could hear the motor running but no step movement. I got underneath, pulled the motor off and verified that it and it's gear were moving in sequence with the door open and shut. All was ok. It appears that the main gear was jammed up against the stop. I got if freed and the steps swung ok. I put everything back together but now the motor runs but the gear on the motor isn't turning. It did fine when I test ran it by itself. I am thinking that maybe there is a problem with control module but not sure. Any comments or suggestions? Thanks!
  • Under the motor gear are 3 cushions to absorb the start and stop shock. I suggest they are collapsed. Remove snap ring on shaft and pull off gear.
    Link to cushions.
    Richard
