Rangerman375
Sep 01, 2015Explorer
Kwikee Step Problem
I've searched the various forums but haven't found a problem just like mine. I am currently in a campground so I am not able to obtain the Kwikee 4 wire pig tail to test my steps. Nor do I have a multimeter.
The steps on my class A will not extend. They have been working fine all season and are properly lubricated. I travelled about 100 miles today when I departed everything worked but when I reached my destination the problem started.
The yellow courtesy light turns on and off when I open the screen door and I hear a clicking sound but the steps will not extend. That tells me that the switch/magnet is working properly...correct?
I plan to tap on the motor as suggested in some posts as well as disconnecting the motor from the connectors and wiring it directly to a battery to see if that helps.
Other than those steps is there anything else that I can do in this situation? I am thinking turning the ignition on an off and seeing if that does anything.
Any other suggestions would be appreciated.
