Lrccci's avatar
Lrccci
Kwikee Step
I need a replacement gear for the motor/gear. Are they available and from whom?
  • One more tip, watch your arms/fingers placement as you work on these in relation to the movement of the steps, especially as you re-apply power to the motor. It is a powerful motor that could do bodily harm if body parts are in the way and the steps fold in. Good luck with your repair!
  • This is some info I have collected over the years from various threads for Kwikee steps.
    Trouble shooting chart HERE
    There is a trouble shooting guide HERE
    If you need sources for motors or parts check the following:
    Motor
    PARTS 1
    PARTS 2
    PARTS 3
    ________________________________________________________________
    " 1) AM Equipment 402 E. Hazel St Jefferson, OR 97352, (541) 327-1546 the motor is $29 plus $7 shipping.
    2) Replacement step motor at AutoZone. It's a Siemens "Window Lift Motor", part number WL43003.
    3) Autozone. The brand is "Siemens"
    The ID tag lists the following numbers:
    59720-20
    121899
    4) A 1986-1995 Ford Taurus left front window lift motor matched my motor. NAPA part # BK655-1395 $63.99 I ordered my motor from Auto-Zone Manufactured by Dorman part# 742-206. This has a lifetime Warranty and was $49.99. "
    Also these guys rebuild the older unencapsulated circuit boards: HERE
    New info in 2012
    http://www.autozone.com/autozone/parts/Aci-Auto-Window-Lift-Motor/1995-Ford-F150-1-2-ton-P-U-2WD/_/N-j1z7uZ8ijybZ1z10l3u?itemIdentifier=972601_315519_1264_1356%2C78656
    Aci Auto/Window Lift Motor
    For your 1995 Ford Truck F150 1/2 ton P/U 2WD 5.0L EFI 8cyl
    Enlarge Image
    Part Number: 83094
    On disasembly of the motor I found the plastic plugs severly lopsided due to all the years of strain, new plugs cost $8.00 at Autozone or Amazon, other than that the Autozone Ford Mark VI would have worked $ $44, but I saved myself $38
    Just rplaced my 25 series Kwikee step motor with a Dorman 742-277 window lift motor for a 1986 Ford Taurus driver side window lift motor. They said the Taurus had a high torqe motor which is why the number ends with 277 meaning high torqe. My steps zip in and out with this motor application. It was a special order item but only took one day for them to get it to my local AutoZone store. I also noticed AutoZone had rebuild kits for Dorman window lift gear boxes (plastic gears) in the Help section of the store.
  • I thought I might need a new motor, but first I got under the steps and used silicon lubricant on all the moving joints. That's all it needed, as KiwKee motors work on resistance for feedback to the motor.
    Otherwise you can reach KwiKee at info@powergearus.com
    HTH
  • I got mine at NAPA. I found the 3 step ones have a slightly different motor than 2 step models. Age also makes a difference since they switched a few years ago.
  • Kwikee motors are small in comparison to Frigette. I believe that some window electric motors are the same size that Kwikee uses on their steps.
