supercub
Feb 22, 2015Explorer
Kwikee Step
My step doesn't close or open all the way. anyone else had a problem like this? I was looking online and looks like there's some limit switches that might need adjustment. I'll check that out first...
BTPO1 wrote:
I was having the same problem that you are experiencing. I took it apart and cleaned everything up lubed everything and reassembled it. I have had no more problems since then. I did do some research for a new motor at that time and for my Kwikee 2 step the motor was exactly like the Ford Taurus front driver side window lift motor. I looked at NAPA and Autozone and both were much cheaper than the dealer. Autozone also came with a lifetime warranty. JMO
