cvbdsl's avatar
cvbdsl
Kwikee steps humming
The steps on my 99 Dutch Start DP 3865 just quit working. They just hang loose and you can push them in and they fall back.
The motor was humming continually and I couldn't shut it off. I taped the motor with a hammer etc but nothing.
I tried the chassis disconnect and a fuse labeled steps (might have been the step lights). I finally cut a wire to the motor to shut it down.
Any ideas or do I have to replace the whole mechanism?
thanks
Chris
  • Thanks all for the suggestions.
    I managed to pull the entire assembly out. The link arm is fine.
    Once I opened the gear box pieces of the gear started falling out. Seems to be in about 8 pieces.
    Now to order replacement parts.
    Chris
  • If it is the gear that is attached to the motor housing it is probably a power window motor from a Ford product. Mine is 3 steps and takes one from a town Car LF. Some take a Taurus motor with 2 steps. NAPA has a book with pictures and can match up the old ones for next day delivery if they don't have it in stock. Those steps are capable of removing fingers if they are in the wrong place at the wrong time. Be careful and count fingers before & after.
    Thanks, but it wan't the motor gear, wish it was, would have been easier to find replacements. It the big one in the gear box.
    Chris
  • Just an update, talked to PPL parts and they confirmed I need the conversion kit.
    The rep said that there are (may) be parts out there but they have had a lot of returns because the parts didn't fit, so now they only sell the conversion kit.
    Not too bad for cost, around $212 including shipping to Massena NY. Hope to pick it up next week as I'm camping in NY anyhow.
    Chris
