Tom_Barb
Sep 02, 2018Explorer II
Kwikee steps locked in the up position
My steps are in the full up position and locked, I've completed the trouble shooting procedures, and found the motor is frozen. will not run in either direction following the step instructions.
All electrical power is as it should be, I have power to the motor, but no operation.
I have tried by-passing the entire electrical system by applying power directly to the 2 pin plug to the motor, I get no movement, and a direct short to ground.
Next step says to remove the clevis pin to release the steps, Problem is, How do you get to it, with the steps fully up and locked.
There is only a slot 1.5 inches wide to work thru.
The step is held to the coach frame by 4, - 1/2" bolts 2 of which can't be seen. let alone putting a wrench on.
