gonzo71's avatar
gonzo71
Kwikee Steps parts
Hi All,
It has been a while for me to post. My old lady finally is giving me a little problem.
My Kwikee Steps are not moving either in or out. I traced the problem to be the control unit.
I went to the dealer but they are having a hard time finding the right part.
I have a Series 25 Kwikee Step. The part number on the old control unit is 90950800, but my dealer can not find that part anywhere. I went to the Lippert website and that number comes up with nothing as well.
Does anybody know if the number changed or is the an upgrade kit I need to order?
Thanks for helping me out.
  • By no means am I an expert in the field but I was ready to replace mine, the controller until I stopped and took the time to follow the tests to the tee to check system as Kwikee has laid out online. Well to my surprise and relief it led me to a bad wire connection in the harness to the controller. The wire inside the harness was green and had corroded to the point of no connection. Cut off a short piece of the wire at both ends of the poor connection. Reattached and sealed connection and re wrapped and steps work great. Cost 20 cents and some time to test and trace. All I am saying is do the test as laid out on the Kwikee website and follow the results to the proper fix. Grounds and wire connections are so suspect on these motorhomes and components. Good luck happy hunting. Let us know what you find.
  • There is a lot of combined Kwikee help on here. What makes you think it is the control unit?
    In my case, the steps would not move. I put my meter onto the motor leads and saw the unmistakable pulse from the control unit, then because they were unable to move, the control unit would trip off internally to avoid an overload.
    When I released the bolts slightly that were holding the unit tight to the frame, that gave a little more clearance and presto, it worked. I put some shims under the bolts and never had another problem with it.
  • IF it is a motor/gearhead you are looking for, many have been replaced with a Dorman power window motor. Check the net for Kwikee Step motor repair. Plenty of info in past, much less expensive than the Kwikee parts.
  • for sale on ebay $139.99 free shipping just ad one more zero on the end.
    https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311.R7.TR11.TRC1.A0.H1.Xkwikee.TRS0&_nkw=kwikee+step+controller&_sacat=0
