Rwake901 wrote:
Gjac wrote:
Rwake, how did you make out with your steps?
Took the motor off and apart it was jammed. So I un- jammed it lubed everything up put it back on and it worked one time then jammed up again. After I un-jam it it works fine when hooked to a battery but when you put a load on it it stops and jam's up. I called Kwikee and they said it was definitely the motor. I have one on order it will be here tomorrow. I can't believe it only lasted a little over two years or course just past the warranty.
Thanks for letting us know , good luck with the new motor.
