Our Monaco has a 2 step kwikee entry system, 34 series I think. They are looking kinda bad. I pulled them off, and sent the steps and linkages off to the powdercoater to be made pretty. A lot of t...
Looks like thanks to you guys, I've sourced the bolts and bushings. Wave (spring)washers sounds like a good idea, and should be easy to find.
Any suggestions on lubricant with stainless bolts in bronze bushings? (almost wanting to think none required, or maybe just a coat of that white sticky anti-seize?)
