racerchaser's avatar
racerchaser
Lack of hot water
I have an Atwood 10 gal gas/elec water heater that no longer provides hot water. The water in the tank is hot but it is not getting into the hot water line. Initially, I was using the elec side and the water turned cold so I switched to the gas side thinking that the elec element had gone bad. I got hot water but not as hot as it should be. Not even that has gone away. I flushed the tank and the water that came out was too hot to touch. Have I got a one way valve that is inop or is there an air block? Little tough to evaluate since the tank is not easily observable. This is on a 2008 Itasca Horizon.
