popeye766 wrote:
Can anyone tell me where the TFI is located on F53/460....It is not on the distributer....I cannot find anything that looks like a normal TFI anywhere....
FWIW, If what you are asking is the ignition control module then look on the firewall of the MH when you lift up the MH hood. You'll need a special star tool to remove it assume we're talking the same thing. I would think that wasn't the problem since they stop completely when they go, there is no surging that I know of.
Also, running the gen does not use the high pressure fuel filter. The take off is a completely different fuel line with a very simple $2 external filter plumbed into it. Running the gen is taking gas out of the tank at the 1/4 level and not at the location the high pressure fuel pump is.
