Because it sold I can no longer see the add or what the price was, but if it was under 10K and all appliances worked and it started and drove, you cant expect a perfect deal. These are RV's and stuff is prone to go wrong, especially on used/older ones, but you have to know that going into it. Especially if they don't get used often, the previous owner may not know the water pump leaks, or certain lights in the coach don't work, but you take it out on the first trip and find this out. If you buy cheap you have to expect cheap and hope for the best, if you want recourse for issues that arise, pay more and fiance through dealer. I learned the hard way by buying private party as a mechanic likely wont catch everything, but could not afford new. I realized before buying that the older it is the more things will eventually need to be replaced no matter the make, but unfortunately you often only find out what needs fixing by using it. I would avoid low mileage older ones that rarely get used, not always the best deal.
