willald
Sep 22, 2020Explorer II
Update:
Got the new motor from Western Motor Service, and yesterday evening put it in. Leveling jacks are working again. :)
A few notes/comments about the WMS motor I used:
Some comments on the thread on IRV2 forum suggested that the polarity is reversed on this motor, and you have to reverse the two wires. I found that not to be the case, the polarity of the two sides was marked correctly. I believe WMS corrected that at some point.
The access port on the back to run the motor manually if you need to, is not quite like the one the original motor has. There is only a paper sticker covering it, not rubber like old one. I may well look into putting a better cover on it, don't want dirt getting in there. The connection is just a slot, not an allen head like old motor. You'd have to connect a regular, flathead screwdriver attachment to your drill to manually turn the motor. May not work quite as well as the allen wrench connection old motor has.
On the output side of the motor, The slot was ever so slightly too small, and coupling link would not go into it. A few minutes filing down the two sides of the coupling link solved that problem, though. Motor then bolted right up, and works great.
Old motor will be going to a local motor/alternator repair shop I've already talked to that is willing to rebuild it. Once it is repaired and working, will keep it handy for a hot spare.
At any rate, bottom line is the WMS motor works perfectly, and costs less than half what the original replacement motor costs that LCI, Amazon, and a few others sell. Wanted to post this, so anyone else that has to replace this motor will know the WMS motor works fine, and will save you several hundred $$.
Now that we got the jacks working, time to get back out camping. :)
38,782 PostsLatest Activity: Aug 30, 2026
