- FEDownerExplorerIs the pane blinking? Check the plug on the control box. It's located in the middle storage compartment.
Also on the pump there is a manual hex key, use a cordless drill to turn it and you can raise or lower the jacks - Jabrad_s_PapaExplorerI have the same MotorHome 06 Daybreak. A couple problems I had with my jacks. My pump wasn't working and we found the clamp on the battery post was loose. Cleaned it and reattached it and all was good. Also there is an inline fuse just under the front bumper area. It is hard to see, you need to climb under and look up. Also check your parking break.
- azdryheatExplorerIs this a new vehicle to you? Does the engine need to be off or on for leveling? Does the parking brake need to be set?
- 12th_Man_FanExplorerNeed more info.
Is the pump running?
Is it doing anything?
38,769 PostsLatest Activity: Apr 03, 2026
