klutchdust wrote:
You have an overhead bunk, what I have is an aerodynamic nose cone that is secured onto the roof of the original cab roof and then is mounted / fastened to the house.
Look at a photo of a Cambria then you may understand . The nose cone on the cambria has no steel structure inside, it is fiberglass. It moves.
Hmmm ... that's different than our 2005 Itasca's construction ... so yes, it could do it's own movement thing relative to the cab.
Other than the molded shell itself being less susceptable to leaks, it being fastened to the coach as a separate structure does raise non-integral concerns to me - independent movement being one.
In pictures of Class Cs with that cabover type, I assumed that that plastic molding was merely fit over and supported (in addition to cab ceiling support) by the internal metal framing that was an integral extension of the coach's metal wall and ceiling framing ... just like in our rig. I wonder why they couldn't have designed it that way?
Boy ... you have watch everything these days! Maybe Coach House and Oliver Travel Trailers are some of the very few these days that do it right.
