shaneperch
May 17, 2013Explorer
I would run both ac units which will dry out the air. As that is what a dehumidifier is.. an airconditioner that is in a continuous loop. I would take a wet pick up and I would vacuum all that water up and pull up the carpet where the wetness is . then after that blow air on the wet area also I would get furniture oil so it will displace the water so the plywood won't delaminate although I am sure that HR used marine plywood. in my buses they used marine plywood and there was a leak in the rear where the rubber was pealed, it even rotted in a little spot. I would not delay on this. you should also get a little can of Kilz to prevent mildew smells entering the coach (like me) there was an old leak in my HR and it was from a water line with a hole in it. It was fixed but that smell,, you know what I mean. but you got to pull up the carpet. I used to clean carpets for a living.
38,769 PostsLatest Activity: Apr 03, 2026
