dougrainer
Nov 11, 2021Nomad
https://www.rvupgradestore.com/Lippert-177420-2-Quart-Hydraulic-Reservoir-Kit-p/177420.htm
Click the link. What you need is the o-ring. LCI does not sell the o ring. BUT, if you cannot find and match a O ring, buying the reservoir kit is cheaper than a new pump. Also, depending on your year, you may need to make and install a support bracket to support the reservoir to relieve pressure on the O ring and flange bolts. Doug
38,782 PostsLatest Activity: Sep 10, 2026
