dougrainer
Nov 11, 2021Nomad
Second Chance wrote:
There should not be any pressure at the tank/pump interface so, unless the tank is overfilled, fluid should not leak there. I would look carefully at the pump itself and any attached manifolds. I had a leak in our Lippert system - but it was from the manifold that controls the slides.
Rob
When you have a O ring that fails, it does NOT take pressure for the reservoir to leak. Doug
38,782 PostsLatest Activity: Sep 10, 2026
