bobndot
May 10, 2022Explorer III
Wade44, you could not be more correct !
Ever look at how many people are suing Thor for build issues , engineering design problems ? Nothing like plopping down $300k for something with build flaws and no remedies.
Chris, im sorry you are having this problem and appreciate you updating as you proceed.
I did notice how optimistic you are and appreciate your humor in your update post, keeping this mess on the light side is going to be a plus to find s solution.
I wish i had some experience regarding the wheel wells. But as Wade said, its probably just staples and caulk holding things in place. I say this due to the way i have seen them blow apart when flat tires cause wheel well damage.
You will probably get to a point of disassembly where the black tank will just fall onto the ground.
Chris, would you be able to access the wheel well from inside the rv ? I read that a class C owner lifted the plywood under the dinette cushion. It was sheet metal and you might be able to to have access.
