SJ-Chris
Aug 27, 2022Explorer II
vidotchis wrote:
It's very difficult to empty the toilet every other day, especially during camping days. Is it possible to remove the cassette from the toilet and fitting a holding tank under the van? Maybe a Plumber help to install a submersible pump to empty it.
You are talking about changing your cassette toilet into one that has a holding tank. I'm guessing that it would be hard to find the space under your van to install a holding tank of any significant size. If you found one that fit, then yes I suppose you could connect it to the toilet and then you would have a holding tank. To empty the holding tank, you would want to dump valve (likely blade valve) near the lowest point and then you would need to dump it at a regular dumping station. I don't see how having a submersible pump would be a very good option.
-Chris
