Geocritter wrote:
rgatijnet1 wrote:
Since you do have a lot of rust under your coach, it might be a good idea to do a visual check of your steel brake lines. They can rust out and rupture at the worst possible time. Of course it is a good time to look at the rubber brake hoses also.
I checked over the entire brake system last year when I replaced the systems 20 year old DOT 3 brake fluid with DOT 5.1 brake fluid. The brakes were in surprisingly good shape. However, I do plan to overhaul the entire system next winter when I'm in Arizona. That's when I hope to replace the rear axle seals as well.
Steve
Oil soaked brakes will become sticky. This will lead to the brakes locking up, overheating, and possibly a fire. Oil soaked brakes are less effective and generate more heat than dry brakes.
