Cras108er
May 22, 2017Explorer
Leaking Fitting on 1998 Bounder
I have a 1998 Bounder with a water leak from one of the fittings. It appears the leak is coming from a fitting that is wedged between the gray water tank and the basement wall. Its almost impossible to get your hand in between there.
My only option appears to be to drop the gray water tank, but I am concerned about how difficult a job this might be. I see several bolts on the front side, but do not know what be behind it.
The problem may have been caused when I hooked up to city water without a regulator. Water started seeping through the floorboard in the middle of the coach. It stopped once I disconnected, but continued to leak from the fitting.
Anyone have any suggestions for fixing this leak? Thx!
