- Old-BiscuitExplorer IIITurn water source off
Disconnect water line at toilet
Remove hold down nuts on toilet base....you may need to remove outer shroud on toilet base to access the nuts.
Lift toilet up off floor flange. - 1492ModeratorMoved from Forum Technical Support
- harold1946ExplorerThat depends on the make and model. If you know those two things, go to the manufacturers website and you will find instructions and part numbers, probably in down-loadable PDF format.
38,768 PostsLatest Activity: Jan 26, 2021
