silverclip2
Oct 21, 2013Explorer
Thank you phnguyk.
I tried to take photo but it hard to show waves or delamination.
However it same usual problem that rotting the wood under the skin. Causing the glue on aluminum frame to rotted thin plywood to skin helpless.
My coach has delam at a small vertical section above the right rear dual.
And most of the left side is delam.
My question is there anyone (DIY or expert) that had done the repair with instructions and/or photos
I am thinking of installing several strip of aluminum channel horizontally (about 5/8" wide x 1/4" sides x 1/16" thick) screwed to frames at 8" inbetween spacing. To hold and smooth the skin onto the coach's frames. ??????????
Any help is greatly appreciated.
Thank you kindly, Sojourner
38,708 PostsLatest Activity: Mar 05, 2025
