cbshoestring
Jun 07, 2015Explorer II
CTD wrote:
Probably the caulk was an effort to add rigidity to the toilet. Most likely the reason it wasn't caulked all the way, was to allow a warning you have a seal leak. FWIW
This is why I always leave an opening on the back of a residential toilet...don't want to trap a leak, you want a warning long before the floor rots out.... but as said previously, RV toilets are not normally caulked. Could be someone was trying to hide a problem, possible not knowing any better.
Changing out the rubber flange gasket is a pretty easy fix for someone handy if the above fixes are not the problem...yes Rubber, not wax RV DOC agrees with me.
However, be careful what youtube videos you watch. I was going to post one for you here....first one I looked at....they put the bolts on the toilet, then tried to rotate them onto the flange.:S
38,769 PostsLatest Activity: Mar 31, 2026
