RJL's avatar
RJL
Leaving tomorrow for Fla
Just got our MH back yesterday with the towing system to tow our JKUR. I had 6 new Michelins put on at a local tire store immediately after we unhooked the Jeep. Got it home changed the oil in the MH, refilled the propane, fuel and am gonna change the oil in the genny this morning then fill up with fresh water. I noticed a stop light bulb was out last night on my way home from the propane refill so gonna replace that too. It's a 1200 mile trip from our place in NJ to our destination in Fla. How many miles do you all drive in a day? I figured if I can get 600 in tomorrow, 500 in Friday we should be good to go Saturday on our final leg. Is this too aggressive? Maybe 500, 500 and 200? Or even 400, 400 and finally 400? I'd like to finish up with 2 or 3 hours of driving. Anything else? Any suggestions? I figure I'm gonna take 95 down the whole way and leave about 0800-0900.
Thanks
Bob
  • Driving 500 miles isn't too bad if you leave very early (dawn) to allow for traffic, weather, accidents, fuel stops etc. That way you can arrive early afternoon at your stops and rest up before the next day. 500 miles is 10 hours of driving.
  • Ivylog's avatar
    Ivylog
    Explorer III
    How much air did they put in the tires? How much does the placard besides the seat recommend? If they put the max sidewall pressure in them (30 more than recommended) you'll be lucky to make 300 miles/day. I would weigh at a truck stop and adjust pressures per the axle weights. New tires and too much air makes for a poor handling rig.
    I really am trying to answering your question as it depends on how well your rig handles and how well you handle it. If you are not used to driving something with a long wheel base it's easy to over steer it. I still do the 1500 miles to CO in two days BUT I have a DP that handles very well with very little steering input. Your mileage will vary. GOOD LUCK
  • I-95 through SC and parts of the other states is so rough that it will surly test your coach to insure that everything is secure. The rough road also takes it's toll on the driver.
    Drive until you feel TIRED and then look for a place to stop. Don't go by miles driven. There are plenty of RV parks along I-95 and we have always found a spot to spend the night, without any prior reservations.
    Your first day you will have to deal with Philly, Baltimore, and DC. By the time you get past them, you will be ready to stop.
