  • I also purchased some from ebay till I found the ones that suited us. We ended up the same as Ivylog with the warm white throughout. You can order small quantities cheap and try them for a while till you find what you like. We ended up replacing over 50 bulbs in the process, throughout the coach. The ones in the ad you referred to are for 110v and would not work in the coach lights I do not think. A few on ebay are polarity sensitive and most are dimable, but have progressed rapidly in the past few years, read the ads as carefully as possible. Hope this may help. Happy Trails Bert
  • Ivylog's avatar
    Ivylog
    Explorer III
    I've had good luck with EBay/China warm white G4 12 5050 LEDs... less than $1.
    I recently went with daylight/5000 temp in my hitchen at home. I like them better than the warm white I replaced. They do not have the bluish color of bright white that I do not like except for outside use.
    At today's prices I would buy several different styles and see which works for you. I have found the 5050 run cooler than 5630 chips. In the past I've only recommend warm white but try some in the 6000-7000 temp/color.
