RoyB
Apr 18, 2017Explorer III
Led dimmers work differently for LED light than for regular incandescent lights... The LED DIMMER changes the pulse width of the operating DC voltage to create the dimmer light output. You just can't reduce the 12VDC feeding the unit.
This is probably what you need to do just for the one light or even for the whole series of lights... Search AMAZON for different LED DIMMERs to use... I suspect all of these LED lights are fed by the same 12VDC source.
Something like this perhaps... Very inexpensive... You would want to know how many 12V DC amps your current zone is using to see if this is able to handle your present DC Current needed...
LED SUPERBRIGHT
Roy Ken
LED SUPERBRIGHT
Roy Ken
38,783 PostsLatest Activity: Sep 09, 2026
