rekoj71
Aug 04, 2016Explorer
4x4van wrote:
Here's mine:
Cheap ($20, Amazon) 16' strip, 600 3528 LEDs, waterproof. Cut into 4' sections for use under the cabinets. Fantastic light, super low power consumption, 2 years of use without a single failed LED. YMMV.
These are like the ones I have and they were easy. I haven't had a problem yet with voltage fluctuation and I haven't had any burn out (it isn't my primary light source though) They are 12V and just need to be soldered to the power wire (there are other connectors available) or if you want to run them on 120V you need a transformer (like a computer brick), and they have 3M tape on the back so they just stick up. You see the waterproof versions on the outside of RV's pretty often too.
38,776 PostsLatest Activity: May 15, 2026
