I am in the process of mounting a modern TV in our 05 Bounder. Most of the non articulating wall mounts just hang the TV on a bracket. What do you use to keep the TV from bouncing off the bracket? My...
I mounted the plywood solid put a big hole in it to access all the cables and plug in back.mounted tv to a removable mount and used small angel brackets 1 on each corners good and solid and can be removed easly.
