Krusty
May 01, 2019Nomad II
If the front turn signal is flashing fast, then the rear probably isn't powered by the trailer circuit. After testing all the fuses (make sure to test fuse F2.15 in the fuse box under the dash), I would check the turn signal switch and make sure you have power out of the switch on the LG/WH wire.
Related Content
- Feb 01, 2026Community Alumni
