TLWNF
May 24, 2013Explorer
bobcat66 wrote:
The O-Grill 1000 might just fit in the rear storage area. The grill is 8 1/2" high when folded down and may stand up in the right side of the rear storage space.
http://www.campingworld.com/shopping/item/o-grill/48961
A couple of Free Spirit SS dimensions that people asked about
I did some measuring of a couple of areas. The big area in the back storage would hold that O-Grill. The area is 9" deep by 26" high by 24" wide. There is one vent pipe that intrudes into the space at the top.
Some have had questions on the distance between the end of the bed and the door. It is 16". The width of the area with that distance is 44". On either end of that distance you then run into the screen door frame and then lose about six inches.
Having now dry camped in the Free Sprit I can say it exceeds my expectations. Everything worked flawlessly. What a joy to drive and camp in. Stays warm at night. 40 degrees outside and heater only came on a few times all night.
Bed is comfy and plenty big enough for two. Did not feel confined whatsoever. Shower was wonderful. Since dry camping we used the water on and off method to preserve water but if hooked to water and sewer you could just let it run all you want.
I have found forums to be so useful and appreciate people providing info, etc. so I want to do my share so if you have questions about the coach I will be glad to answer them.
