TLWNF
Jun 13, 2013Explorer
hrow wrote:
Thanks for the info, it is much appreciated. Is there any storage under the bed?
Sorry, forget to mention the under sofa storage. There is drawer under the sofa that is the length of the sofa and a little over 2' feet back. The drawer is about 6" deep, i think. It stores the larger table and the leg. Also, the slideout locking rods are in there. We don't use the locking rods and another person I know took out the large table and just uses the small table. The small table works good enough for most uses unless you have a larger meal you want room to set up for. A trade-off. So what I am getting at is you could get by without the stuff in the drawer and use it for some bedding.
Another area that can be used is the cab area. While parked lots of stuff can go there including the bedding during the daytime. Then on the road, the bedding could just go on the couch. Other things you haul can be done the same way. Also, we use the shower to store stuff and just remove it while showering then but it back. It is a Class B but you will find there is way more room than you can imagine. And with the slide out, there is so much more open, truly usable floor space.
